Anyone have any idea on this problem?
We were out on a run the other day, and Steve was complaining about his cruise control not setting. I had noticed from time to time, that he appeared to be running with his brake lights alight, and thought that if he had his foot resting on the pedal activating the light (but not applying the brakes), that could be his problem.
When we stopped and talked about this, he maintained that his foot was well away from the pedal.
On checking the brake light activation, the rear brake would only light the brake lights intermittantly. OK then; faulty switch.
The front lever lit the lights every time.
Now, here's the problem.
When we set off again, we did some tests.
If he only used the rear pedal to brake and then ride on, the cruise would set instantly.
If he used the front lever, the cruise would not set and he had to 'flick' the lever a few times before it would lock on again.
I was behind him, and everytime he flicked the lever, the brakelights would flash.
So. What is the problem? And how can it be fixed?
Any pointers would be appreciated.
Thanks.
Thanks.
