First thing to check are the switches at the levers on the handlebars... Especially if the PO replaced the stock levers with after market ones... You should hear the clicks (2) of the micro switches as you pull in the levers...
When trying to set the cruise, try pushing forward on both the right front and left front lever and see if the cruise will set... If it does, you may have worn bushings on the levers or the after market levers are giving you issues... Some guys add a little shim at the end of the lever to actuate the switch when this happens...
It could also be a dirty or sticky "set" switch... You could also try spraying some contact cleaner into the "set" switch and see if that helps...
Les
Les
