My cruise has had two issues that I have yet to solve. It started out that the cruise was unpredictable in setting. The cruise set light would come on for about 1-2 seconds and then go off. Eventualy, it would stay on during the current ride or next ride. If the brake or clutch is activated, the light won't even turn on. Therefore, it doesn't appear to be an issue with the cruise turn off permissives since the light does come on for a bit.
Now when I am lucky enough to get the cruise set light to turn on, the cruise doesn't lock on to any speed. The bike just decellerates down. Also, I need to be up around 85 to get the cruise set light to even turn on. Normally, the cruise does work as high as 85. This makes me think that my speed signal has an issue requiring a higher speed than normal to register a high enough voltage to the speed controller. Any suggestions from this limited info.
