GL1500 dash removal
1 reading
12K views 3 replies 4 participants last post by  Robin
#1 ·
hi could anyone direct to to a thread on how to take off the front speaker cowls i need to get the speedo out pics would be a bonus but any help will do (gl1500). im hoping that i dont have take the whole front end to bits . thanks for your time in reading this plea for help( dave)
#2 ·
Back in July of 2009 this was my first question after buying my Wing. Here is the reply I recieved from RUDY. Follow the steps & you too will be removing your dash like a pro....-Rich
This was posted by Rudy on your subject. Hope it helps!
""To get there you have a series of not too hard steps.
Here is how I do it.
Remove the seat.
Remove the two fairing trays under the handlebars.
Remove the key ring and bridge piece.
Take out the two acorn nuts that hold the upper shelter at the front of the seat area.
Lift up the upper shelter and remove the green ground wire from one of the 4 radio mount screws.
Get into the back of the radio boot and unplug the Radio plug, the CB plug and the FM antenna. These will have catches you need to release in the middle of one side. The big one is a rough one.
Remove the upper shelter with the radio still attached and set it aside. (I recommend using towels to protect your paint when putting this part back on later). (This is a good time to change the air filter)
Remove the headlight adjuster knob.
Remove the nut for the adjuster and it's washer. Leave the rest sitting there.
If you have an adjuster knob on the other side for air vents, remove that side too.
Remove both fairing boxes.
Put the windscreen latches at half mast.
Pull the rubber mirror boots out and remove the mirrors (3 long phillips screws) and get access to the screw that holds the windshield cover piece on each side and take those screws out.
Remove the windshield cover piece.
Either loosen or remove the windshield. (good time to add better headlamps)
Remove the levers and the special wide head screws that act as a pivot for the windshield levers and also remove the spring steel plate. Do not let the adjuster mechanism drop behind the plastic. Put those wide head screws back in but just slightly.
This will allow you to push back the mechanism safely to clear a part that must go in to allow the front bezel to come forward.
Remove the two vents in the dash. These are a little tricky because they are 4 plastic catches molded into the frame of the vent itself that ratchet in past two layers of plastic per vent. They must be compressed inward of the frames to release. To make this easier on myself, I made a tool out of a 1/8" blade mini screwdriver. I bent the shaft of the screwdriver 90 degrees so the blade looks like a hoe on the end of a handle. This allows me to slide in between the vent frame and the dash surface and compress each tab one at a time. It also lets me pull outward on the vent at the same time and get a corner sticking out. I hold that corner while I do the other tab on that same side. Now holding the whole side out a little, I go after the bottom side tabs. Once you get it all out, do the other vent.
Now the dash panel will come free.
You now have access to your speakers. You also have access to your instrument cluster in case it is time to change all the bulbs in that.
Going back together is easier because the vents just snap back in.""
Thanks again to RUDY....-Rich
#3 ·
http://www.goldwingfacts.com/1500windshieldremoval.htmhi dave on the link is the windshild removel your half way there afetr the wind shild remove the chrome screw on each mirror mount that releases the ajuster then the two nobs for the vent and headlight ajuster and last the two small vents clip out and the ignation pannell the dash cover will then come off and 4 screws for the dash its self
Save
#4 ·
Dave
I took out my speedo last month, its not to difficult.
Remove air vents (use a fine probe to hook up the tabs)
remove fairing pockets
remove light and air vent knobs
remove mirrors and trim
you then have access to chrome trim, remove
take of screen locks
remove screen
take off dash.
Think i spent about an hour taking it all apart, putting it back together was quick
Save
