1 - 13 of 13 Posts
Need help diagnosing: I can start my 96 1500 Aspencade, runs rough, then when warm starts to faulter, all electrical blinks and then total system failure - happens about 5 minutes into starting motor. I appreciate the help!
possible bank angle sencer also check all of your connections make sure they are tight & then I would check my alt !
Check main fuse "A" and the plug connector on starter solenoid "A".
What is your voltage before starting, running and after it dies?
Loose battery terminals?
After it dies, does it still have the ability to crank over?
Discussion Starter · #8 ·
Replacing bank angle sensor today; checked out voltage readings all doing well; checked all connection, A-OK...
Total battery wipe out. Change battery.
Monkey with a Football
Check battery while running to see if it is charging.
I'm betting not.
I'm betting on bad battery. Would check alternator output for proper - voltage it could be heading south.
Discussion Starter · #12 ·
BANK ANGLE SENSOR REPLACED; STILL SHUTS DOWN ABOUT 10 MINUTES... Replaced battery, still shuts down; checked all connections looks good... Alternator output is lousy..
What is the voltage output?
1 - 13 of 13 Posts
