Hello wingers. I have a 1995 SE with 73,000 miles on it. I bought the conversion harness to turn my fairing side marker lights into signal lights. When I installed the harness I tried the blinkers out and the front fairing light no longer flashed but the fairing side light and the tail signal flashed but at twice the speed as normal. I thought these were plug and play. What am I missing? The harnesses are show chrome brand.
It aint rocket science
To what and where are you plugging in to.
There are three wire male and female connectors that plug in between the front turn signal light and the other end of the harness has two wire male and female connectors that plug in between the side marker light plug. I will try and install it again. Maybe I did not get it plugged in all the way at one of the plugs. Thanks for the replys. I will let us know what I come up with.
Update- Found the problem. One of the wires was broke at the male three wire connector where it was crimped. I repaired the wire and all is good! Thanks for the responses.
