Is the Mobil 1 synthetic 75-90 good to go in the final drive in the GL1500? the PO doesn't remember when it was changed last so I figure I'd better do it.
You are good to go Lucas makes a good Synthetic too I have it my 1200 LTD and I have read a bunch of people doing the same thing with very good resuilts.One thing if it hasn't been changed is when you change it when you do it make sure the oil doesn't smell burnt you will know because it really stinks and the only thing you can do is replace the rear end good luck and May God Bless.
Thanks Freddie, all I have to go by is the PO's statement that he followed the maintenance schedule, but he says he only changed the brake fluid, not the clutch fluid, so I better change both of them as well
A little preventive work really goes a long way and helps you feel better because you know that it had been done.When I was growing my dad had a garage and he worked on trucks and had to put a new rear end in one he pulled it and the axels and such that had gotten hot everything was shot and once you ever smelled burnt gear oil you won't ever forget it that is some nasty stuff.Take care and good luck.
