Any suggestions on where to get replacement rubber pads for footboards? I don't know who the PO bought these from or what brand they are. Or is there a place that sells small sheets of this material I could cut to size?
a hardware store or HF will have something that you can cut down and cement back on,about the best thing i have found,i have seen replacemnet pads for the floorboards themselves but never the shifters
I had a similar problem with a set that came on mine,(went back to stock pegs) I contacted a vendor on Ebay that was selling the floorboard set up...they had the insert you seek...but unfortunately I dont remember their name...I know this isnt much help but maybe a place to start...good luck
Banned
Go to a auto parts store and buy some rubber floor mats that have a pattern that you like.
Template/Trace/Copy the shape.
Once cut to size, clean board and new rubber with alcohol and use 3M Super 77 spray adhesive according to directions; spraying both pieces and waiting 5 minutes before applying.
Just don't get 'Yosimite Sam mats.
They look like Markland, although I'm not 100% sure.
That helped! I did a search on this forum for Markland and found someone else asking the same question, with a picture. Looks the same. I'll try to find some of those, and if unsuccessful, will check HF and Autoparts stores.
floorboards
Those look like Drag Specialties floorboards. The pads are listed on the site that Newday777 posted on his response. Good Luck.
