After I got the carbs back together and the bike running, I've noticed a faint fuel odor, its been getting stronger lately, so I started investigating it little further.
I've noticed the left carb is wet, and weeping from the fuel inlet. due to where the inlet is on the right carb looks like I will need to remove them again. If I remove them I'm going to replace the fuel line, and line clamps. What is the best style of clamp to use on the fuel inlets to the carbs? Also what size fuel line will I need?
Second part, Who's using a 12v fuel cut off valve in place of the vacuum valve since I see the rebuild kit are no longer available.
