Sorry for the length of this post..
Two yrs ago I went on a trip and ended up getting stranded about 5 hours from home. The issue was the alternator. The voltage output was not consistent as the revs. increased and therefore the fuel pump didn’t get enough voltage to work. I replaced the alternator with a CompuFire and the issue went away. Now then about 2 wks ago I was taking a quick afternoon ride and the bike began to sputter as I cruised about 70mph (cruise control was on). If I gave it more throttle it just started to bog down. If I went back to cruising about 65mph then the situation cleared up and I could give it momentary bursts of throttle. But if I went back to cruising around 70mph the issue returned. I think that it was only getting enough fuel to barely supply it at that speed.
What are the thoughts on this? Is it fuel pump? Or is it a carburetor issue? I notice that the fuel pump doesn’t pump with just the ignition switch on. The motor (or starter switch) must be on. Is this normal?
Does the carburetor need a rebuild? Also I hear a vacuum leak when I use the choke. Is this right? Or is it a vacuum leak?
The bike has about 85K on it and it’s a 1996 model. Should I just rebuild the carb and replace all the vacuum lines? (scary thought!)
HELP!! I can’t ride. :needahug:
