How do I drain the tank?
Will the plastic measuring spoon desolve in time or will it be ok?
How do I get it out
I would think you could remove the seat, and take out the fuel pump to get to it. Once fuel pump is out you should be able to fish it out. ( No cigarettes please).
gumbyred
Steve
Before removing the pump under the seat, the gas has to be below 1/2 tank or it'll go all over the place when you pull the pump.
Not sure if the measuring cup will hold up to the gas or not, depends on the plastic type.
Get a hand siphon pump from auto parts/harbor freight.
To answer the question of the plastic measuring spoon:
Answer.
I removed the fuel pump per Gumbyred (thank you and was able to retrieve the spoon.
It was soft and beginning to breakdown. So it is a good thing I fished it out. and am part of this forum so I could get the needed info.
Thanks again
Steve
Answer.
Thanks again
Steve
