My gl1500 is having a starving gas problem. It started on 200 mile run at 100+ temperatures. Lost power and I crippled home at about 25 miles per hour. Acting like it was't getting enough gas. Changed fuel filter. Tried again, same problem. Changed fuel pump and lost power about 20 miles out. This time the wing died and would not start. Caught a ride back to house to get trailer and went back to get the wing. Probably took about 30 minutes. When I got back to the wing, I tried to start it. It busted right off. I jumped on and road it home. Before I got home you could feel the motor acting like starvation of fuel, but I made it home.
Is it the ECU causing this problem, and how do you check it to see if it is good? Where can you buy a new one? Saw used on flee-bay but how do you know if they are good? Any help appreciated.
