After shorting the BAS red/white wire to ground through my test light I was able to get the starter turning ( again),,, further thought and investigating, The Green wire on the BAS has voltage on it,,
After using Two digital voltmeters to measure resistance, I have a huge resistance to the green wire in the BAS connector and the green wire to the frame back by the BAS sensor, it goes into a saddle bag.
My Battery ground to engine ground is 50 ohms,, Too much I know,
but is there other Grounds on this bike,, having several ground places is an issue in test equipment I design ( Engineer for Raytheon)
Can someone tell me where other main ground are and I can start looking,,
Thanks in advance for all the advise so far, greatly appreciated.
Rich
Rich
