GL1500 headlamp
800 Views 11 Replies 4 Participants Last post by  DBohrer
ok anynoe know how one would replace the lamps on a 1500 nothing in the owners manual
1 - 12 of 12 Posts
which lamps are you replaceing ? head lite---tail lites--side lites--?????
need to replace the head light i know there two of them one of them out wild like to replace both of them
oops typo not wild but would lol
funny thing i just done this yesterday---lets see if i can still rember it all----remove (loosen mirror trim atbase of rubber boot) remove windshield outter trim retaining screw at each side---tilt forward and remove---remove 2 screws from the lower plastic grill (thats be low the headlite lense)-remove grill--now you can see the 4 monting bolts that hold it togather--the 2 bottom bolts have threaded holes in them for the grill screws --the top 2 dont---remove bolts--at this time the headlite assy will come out--(dont loose the 4 meteal collar washers , 1 per bolt)---unplug h/l harness from plug ---ok that has the headlite assy in your hands.---from the back side--loosen sealing rubber boot at the big end lift it up to see the locking wirer for the blub --unlatch and remove blub. reassy in reverse order. carefull not to handle the new bulbs with bare hands-- use a clean paper towel. oil from your hands will case a hot spot and take the blub out. hope i rembered every thing.
Here you go: GL1500 Headlight Bulb Replacement
One additional tip, if you release the windshield adjustment lever (the one for height adjustment), it's easier to access the screw at either end of the large chrome piece.
wow thanks for the info great thanks for the help
However, the procedure is in the Honda service manual. That's one of the first things I purchase when getting a new bike. They will soon pay for themselves.
i agree Dbohrer on the service manual I guess it time to get one lol
;)well---- how it go ? ? get`em replaced ? :action:
Yep, I also would like to know.
1 - 12 of 12 Posts
