Trip piece over light ?? sorry what is that? do I need to replace it to make the new style fit? Thanks for the reply
I think he means the later type chrome garnish, which you don't need to fit if you only want the later headlight. Most owners go the full Monty and replace the garnish also, in which case you need the bracket that Steve mentioned.
If you also decide to fit the later style turn signals, you will need the bulb holders too because they are a different fitting than the earlier ones.
But, if all you are replacing is the old headlight with a newer one form 1995-2000, all you need is the actual headlight.
