1 - 11 of 11 Posts
hello all..i am at a loss. i cannot get my low beam lights to work. yes both bulbs are good. fuses all fine. i replaced the 20amp circuit breaker for low beams...still nothing. i removed the hi/low switch and checked that also.
so what am i missing? hi-beams work great,in fact, that's the only way i can ride now...i need some advice :?
mmonsterbuck
ok try this, worked a 1500, spray contact cleaner around the starter switch,work it as u spray.this bikes headlights would go on n off as u tried 2 start it. this worked. or u may have 2 take switch apart. be careful, they may have a rocker inside,(brass) with small spring inside. dirty, spray with contact cleaner. u might b able to do this 2 headlight switch without takeing it apart also.
ok sounds like something to try...only thing i am not sure of..is why the hi beams work starting or not??
The start switch would interrupt both low and high. Check the low beam relay.
It aint rocket science
Are you sure you got the correct relay location? It is the top left.
JD
JD
yep..put a brand new relay in the #1 position accord to factory manual
Remove the relay and check wires at panel. Two should be hot with key on. Of the other two one is a ground (check that). The last one will be the feed for low beams. Use a jumper and apply power to that lead and the lights should light, if not, trace the wire for an open.
JD
Shouldn't it be the #8 relay?
Hi Dave,
This is from a 90 Shop Manual.
JD
OK, that is different from the manual (CD) I have. It is 95 I think. I knew the 88-89 was different and do not have 90-94 ETM so I made an assumption I shouldn't have. It does look like the same fuse/relay box, just different locations for the relays. If that is an aftermarket manual I would still be skeptical.
Discussion Starter · #11 ·
i found it!!! i removed the fuse/relay block to access the back. wiggled and jiggled wires for awhile. i could get the lights to come on occaissonally ,but never stay on. then started wiggling relays also.same results . finally i wiggled #8 it would come on and stay on till i jarred it again. removed the relay to find the terminal had been overheated at some point...i repaired the damage and seems ok..will re-test several times before i button things up
thanks
1 - 11 of 11 Posts
