Bike runs, no headlight, instments, neutral switch indicator, kickstand switch does not shut off engine. All relays good, all fuses good, new ignition switch. What would you recommend next? Where can I get a readable wiring diagram?
Welcome to the forum gwinger68
There is a diagram in the repair manual. #1 tool for these complex machines.
No high or low beam? Bulbs blown?
It could be a dirty high low switch. Spray with electrical contact cleaner and work the switch a bunch and lots of spraying. Protect the painted fairing parts from drips and overspray.
Be sure and post a reply back on this post as to the results, stay on this post don't start a new topic on the headlights and ask if more info needed.
It could be a dirty starter switch , - there are two functions in there , (actually two switches ) , one controls the starter , and the other disconnect the headligt etc. when you push the button and reconnect when you release the button.Iff dirty or burnt it wont connect again , - take the switch apart and have a look.
I know you said you checked the relays, however, these symptoms look very much like a faulty relay #3.
