I have a 1988 1500 tore bike down to check for a vacum leak due to bike keeps wanting to act up and run on 3 cylinders can't find anything after tearing apart it is running ok again so putting it back together and noticed headlight now won't work I Have no juice to it any ideas where to check for any connecters to see if I have juice coming up thru the bike any ideas would be wonderful
Pwhoever
+1 on the start switch. Try pulling the switch all the way out and see if that does anything. Usually if it is a fuse or relay, it would still work on one or the other but both out would point possibly to start switch.
Found problem was a fuse thanks guys now if I can get it to run on all six I will have it made
