Problem: The pins commonly break off the side panels, causing loss of the panel.
Solution: Lower your standards, and be a hack for a change!... Use common drywall screws (trimmed short),, inserted into the stock rubber grommets. Then drill a hole through the body panel, and install the screw that came with it.
Note: If you ever win the lottery and can afford to buy a new side panel, simply remove the drywall inserts, and you're back to stock configuration.
Show prior to removal of spade-tip
Before and After, trimming of spade-tip
3x Drywall mount; (Upper right screw is different method; goes into drilled/tapped hole, into stock Honda metal mounting stud)
Sure beats losing the cover down the road. I did find a place on the internet that sells a kit to replace those broken pins. When I get back on my laptop later I try and remember to post the link.
rudy has a keeper kit that will keep you from losing any of the paneles suffering from broken pins. GOOD STUFF!!
look in the for sale / wanted theard.
i was able to get by with ford dash panel spring clips glued to side cover in the broken area.
you can find them at any salvage yard.
