my brother has a 92 gl 1500 with brake light issues lights all work fine until bike is in gear then brake lights wont work and the turn signal indicators on dash light up dim we have checked all relays switchs wiring conections light bulbs ect.. there are times when he has no trouble at all
Have to check every circuit. May have to take some stuff off to check.
Have had some factory crimps too tight and cut wire at connector.
Have seen bad BULBS do the same thing. But sounds like a ground issue though.
check frame and engine main ground on the right side of the engine, near where the reverse cables hook up. Also, mine seems to have an additional ground point under the seat, check that one too
