1 - 9 of 9 Posts
I have a wing landing gear and the control module has no numbers on the wire terminals. the instructions show 12 wires to hook up but there are only nine connections on the module, another terminal on the side has a four wire hookup but they are marked. Has anyone got any information on the terminal numbering? this is the one from LA. Not the leg up system
Which landing gear do you have, there are two types that I know of. There was the one made by the guy whose place got hit by Katrina and was wiped out. Also you have landinggear.com. Here are the instructions for the latter kit.
I have the one from LA. he's no longer in business. instruction book has 1999 year in cover the only problem I have is the control module has no numbers on the terminals the number one terminal says to hook to aux. power, I dont know which terminal is #1
19.5kbs is a VBulletin default Joe, and far too low. I wasn't aware of it until I read your posts. I've just set it to 2mbs. Try it again and if you need more than a 2mb limit let me know and I will bump it up more.
I do not have the LEG UP system, but thanks for your help, Tim
2000 GL1500SE
Thank you a lot Steve for bumping up the limit for pdf files. I have known for some time that it was way too low for most pdf files. I have been converting mine to jpg to upload them. That works too but is an extra step. I guess I should have called your attention to it earlier.
I have it at 2.8mbs now Larry, for PDf and jpegs. That's probably a reasonable size without risking breaks in the uploads. I can always up it more if any of you need it later.
1 - 9 of 9 Posts
