This seems to be a recurring issue on your ride, either all twelve adjusters are no good or it is something else.
Could be the oil pressure relief valve is sticking causing high oil pressure although I would expect the oil filter to be blown off by now and I have seen them swelled from excessive pressure OR somebody has been into the engine before and has not set correctly initial valve clearances or done something else wrong.
Attach a mechanical oil pressure gauge to engine and ride it until the next time it screws up taking note of any abnormal readings, should only take two days from your post.
After that it will be a thorough check of valve train and heads.:?
After that throw the whole thing into the river.:wtf:
