1 - 2 of 2 Posts
Hi all.
I have an 88 1500 Goldwing recently purchased.
I am having a problem with 1 of the lights on the cowl? below the gas tank not blinking when the turn signal is on.
All other lights work fine and the other side does blink with the turn signal.
The light does come on with the bike running, but won't blink.
Also when turning on the hazard lights, it still won't blink although all the others will.
I have taken it apart and noticed only 2 wires going to it which tells me the problem is somewhere else.
Any ideas?
Senior Guru
Hi Troy and welcome to the forum as these lights dont come factory fitted you need to make sure that each side is wired right it should be plug and play but some guys made there owen harness and may have wired it wrong also check both bulbs are the same
1 - 2 of 2 Posts
