Hello,
I had a battery drain problem and took the battery to be checked and it was good but very low
They replaced it anyway
It still shows no increase in voltage
I was told to check the regulator before i replace the alternator
Where is it and how do i check it
Thanks for your help
Hello,
My bike is a 1988 gl1500
I ride my bike every other day and everytime it was easy starting till one day it cranked slow and would not start
I had this problem before and when I had the battery checked it was bad so I replaced it and a year later it started again and I had the battery checked and it wad good but the store repalced it for me anyway and after I instaled it I started it showed 12.29 volts, than I took it to the store and back I left it over night.
The next day I hooked up my multimeter and started it it went up and down in volts and than just keep going down
PLEASE HELP
Is this after you run the bike? If so, the bike isn't charging.
If the bike is charging, either you have a draw or bad batteries. Is the place you buying the batteries charging them INITIALLY? If not, that could do it(usually takes 2-3 months though).
...I ride my bike every other day...PLEASE HELP
It's likely that your alternator needs service, probably due to sticking/worn brushes... they need to be serviced every 20k miles.
If you're in a pinch, I have a spare alternator that you may borrow... PM me if interested.
