are you talking about the cornering lamps? you can just connect them directly to a switch and run them all the time
Wel excuuuuse me!!!!!!!!!!!!Dave, If he has the standard cornering lights, I believe he would disconnect the orange/white (left) and blue/white (right) at the relays.
According to the wiring diagrams and my experience, there are no solid orange or blue wires on those relays.DBohrer wrote:Wel excuuuuse me!!!!!!!!!!!!Dave, If he has the standard cornering lights, I believe he would disconnect the orange/white (left) and blue/white (right) at the relays.
If you will look at page 9-3 in the Electrical Troubleshooting Manual, you will see the "cornering lights circuitry". You will see the connectors (example C96, C70, C95, C69 etc. etc.). Then look on pages 11-2 through 11-5, it will show you the type of connector and it's location. Look on pages 12-0 through 12-10 you will see pictures of the connectors.i have the black manual, from honda, for the 1988 gl,
so that means that i have the wiring diagram.
i want to disconect the lights from the turn signal and
wire them directly to the spare 10a fuse in the fuse box.
then they will come on with the key.
easier said than done.
the wiring diagram shows me a junction that i can use to do this.
it does not show where on the bike the junction is.
my question then, is this:
where on the bike is it posible to access this wire?
