I think that was only on the Interstate model.
The player is hard wired into radio amp via the patch cord with no other parts besides a switch.What is so much better with the audio input modification I keep seeing on here.
Reread the mod, no tape required.You still have to put a dummy tape in the player, so why not just use the cassette adapter with the input cord attached.
So you did this mod to your Radio yourself??
Did everything except for the soldering which a friend of mine did. The reason he did it was his bench is set-up for electronic and he is twice as good soldering than me. My bench is set-up for heavier mechanical work which I do for him and am twice as good at that.So you did this mod to your Radio yourself
I did it to 2 1500 goldwings. I tryed the cassette with the plug on it, just didnt sound as good. Of course if you new at soldering and taking things apart, would suggest for you to find someone to do it for you. I think you like it a lots better.So you did this mod to your Radio yourself??
At the moment I'm running the tape in the player with the plug in cord.
Kurt
