Gl1500 no idle adjustment
1.8K views 5 replies 4 participants last post by  rayworx
#1 ·
runs great, but won't idle without choke. It idles fine without choke and a little throttle. The idle adjustment in the gas compartment has NO effect at all either way no matter how much I turn it
#2 ·
I guess it's possible the flex cable to the idle screw is slipping and not turning the screw at the carbs. I doubt there is any way to look at it without pulling the air box.
Save
#5 ·
Dave would you suspect that set of vac hoses under the carb? those seem to be a popular failure recently?
Save
#6 ·
While you are turning the idle adjust cable.... can you feel resistance? It is possible to turn the cable out so many turns that it unscrews from the carbs. At that point the cable pops off, the retainer spring drops off and there's no way to increase or decrease the idle.
If that's not the case I'd agree that there's probably a vacuum leak. Under the carbs at the 90Ëš bent hose is a common leak; at both intake manifolds there's hoses that can leak. Remove the hose and cut off 1/4" - 1/2" and reinstall.
There are a hundred other possible vacuum leak areas but these are probably the most common.
