I have a high pitch noise in cb and radio that goes with the rpm of the motor. I know I have a resister on the outside of the alternator. What can be done or has anyone had this problem? I have a 1995 GL 1500SE with 50,000 miles. Need help:stumped:
i dont know if the 1500 have resisters on the spark plugs. but I know if they are bad It will let noise through
Loyal member
Contct Wayne a Sierra Electronics and he will be able to answer any of your radio/cb related issues.
Other side of the pond
Wayne is a member of the forum too. Search him out and you will be able to send him a private message.
Vendor
A high pitch whine is almost always alternator related. On the 1500 I find the need to replace or clean the brushes and this will usually fix the problem. Sometimes we also find the wire on the cap broken but you said it looked good.
Thanks moon, Wayne gave me an answer and only one answer and that was the Alt. brushes.
Discussion Starter · #8 ·
Thanks Ted, he was able to answer my question. Alt brushes. Will let all know when I replace them. Again thanks. Terry
