Hey guys, I've got a '93 A with Progressive springs. Left fork was leaking so Istarted the basic rebuild on both. Using a Clymer manual and going through the steps I cleaned and inspected the right fork including the damper rod assembly. Everything matched up with the diagram in the manual but I didn't order new stop rings as the manual warns. I'm thinking I'm just going to use the old ones. Anyway, the confusion began while inspectingthe left fork. There is no oil lock piece and one less stop ring (2). The diagram clearly shows the oil lock, which I assume is for both forks. However, according to this manual, the right fork requires 5 cc's less fork oil than the left which would make sense - less oil for the fork with the oil lock as it would push the oil level higher. Basic displacement theory.
I took the bike over at 27k miles and I get the feeling the previous owner didn't bother with things like forks or even basic maintenance, so I don't think they've ever been cracked open. Unless it's a Frankenstein and I've got an Interstate left fork. Butthose are supposed to haveanoillock on the left too.
Any thoughts or ideas? I would appreciate it. Thanks.
p.s. would you use the old stop rings on the damper rod?
