1 - 3 of 3 Posts
Hello to ALL
I have fitted JM HEADSETS to my shark helmets, both my wife and I have notice that only one speaker is working
both external speakers work, so is there something I have setup wrong or is this normal.
the bike i have is a GL1500 1988.
I have gone through the install twice to ensure all is correct and plugged in
if anyone can give me some help
I would appreciate it
:bow:
thanks
if both speakers work on the fairing and neither on your headsets i'd be looking into the connection box coming off the box to the headsets
you might try to find someone else with a 1500 to plug into there mc to test your headsets
I would start by putting both known good speakers in one helmet. If that doesn't work try swapping the bike to helmet cables. If that doesn't work, remove the plastic pocket on the right side that the helmet plug comes out of the under side. From their you can remove the cable to the helmet plug. It's about a foot long. Make sure that cable isn't broken with a ohm meter. Do the same with the rear seat cable by removing the seat first. After that I would make sure the cables to the radio unit are all properly plugged in.
1 - 3 of 3 Posts
