[Re-posting Dave's File, to enable Internet Search results]
GL1500 Parts​
Note: Prices as of April 30, 2019
Partzilla.com​
Name Part Number Fitment Price Each
Accessory (running) 34901-GM0-003 SE Bulb 1998 – 2000 18.68 Need (2)
Light Bulbs “12v – 18w”
34901-706-000 (ATV Bulb 1998 – 2000 3.82
“12v - 25w”
Air Filter 17205-MN5-003 1988 – 2000 33.06
Air Shock Boot RR 52611-MN5-003 1988 – 2000 39.05
Note: It is only listed on the Honda Fiche for 1988 – 1993 but the same boot fits all years.
Monroe Shock-Mate Boot Kit Part # SA1997 (will fit, cut about 3 “ off the top
then zip-tie in place.
Alternator Brushes 31101-MN5-005 1988 – 2000 3.18 Need (2)
Alternator Brushes E480 1988 - 2000
(NAPA)
Alternator Bearings 6022GU (Front) 1988 - 2000
“Aftermarket” 6000DU (Rear) 1988 - 2000
Alternator Bolts (3) 95701-0803802 1997 – 2000 3.37
Alternator Bolts (3) 95701-0803808 1990 – 1996 1.53
Alternator Bolts (1) 95701-0803808 1988 – 1989 1.53
Alternator Bolts (2) 90022-MN5-000 shoulder 1988 – 1989 Unavailable
Alternator Dowel Pins 94301-10160 1994 – 2000 1.52
Alternator Rubber 13534-MN5-020 1988 - 2000 4.79 Need (4)
Dampers
Bank Angle Sensor 35160-MAF-023 1990 – 2000 99.43
35160-MN5-003 1988 – 1989 obsolete
Note: Listed under engine guard
Brake Master Cyl. 45530-MG9-951 1988 – 2000 37.00
Piston Set (Front)
Brake Master Cyl. 43520-MG9-305 1988 – 2000 39.77
Piston Set (Rear)
Brake Master 45504-410-003 1988 – 2000 7.94
Cylinder Boot (Front)
Brake/Cruise Switch 35340-MCA-000 1988 - 2000 9.61
(Front)
Brake Pads (Front) 45106-MT8-305 1990 - 2000 43.21 (Need 2)
45105-MT2-007 1988 – 1989 unavailable
Brake Pads (Rear) 06435-MT8-405 1990 – 2000 40.35
431A0-MT8-670 (w/kit) 1990 – 1993 41.15
43105-MN5-008 1988 – 1989 33.47
431A0-MN5-670 (w/kit) 1988 – 1989 38.43
Note: The only difference is the “kit” includes the retaining spring and shim.
Clutch Master 45504-410-003 1988 – 2000 7.94
Cylinder Boot
Clutch Micro Switch 35330-MB0-003 1988 - 2000 11.90
(For starting in gear)
Clutch Micro Switch 35335-MG9-951 1988 – 2000 15.40
(For cruise control)
Clutch Bushing 22885-MB0-006 1988 - 2000 8.45
Clutch Lever 53178-MN5-006 1988 - 2000 20.98
Clutch/Brake Lever 90114-MG9-951 1988 - 2000 6.03
Bolt
Clutch Master Cyl. 22886-MB4-305 1988 – 2000 43.69
(Piston Set)
Coolant Drain Bolt 90463-ML7-000 1988 – 2000 2.18
Washer
Cruise Filter 36532-MN5-005 1988 – 2000 2.67
Drive Shaft 40201-MT8-003 1988 – 1996 unavalible
Drive Shaft 40201-MAM-A60 1997 – 2000 50.53
Drive Shaft Boot 52104-MZ0-A40 1997 – 2003 14.22
(Valkyrie)
Drive Shaft Boot 52104-MN5-000 1988 – 2000 21.70
(Gold Wing)
Note: The 1997 – 2000 Gold Wing’s need the Valkyrie Boot. Because the Valkyrie
universal joint was installed at the factory. Honda replaced boot under warranty.
Fairing pocket lock 37220-439-007 1988 – 2000 31.91
and fuel door lock
Fork Seal Set 51490-MN8-305 1988 – 2000 21.64 Need (2)
Fork Bush Guide 51414-KCR-003 1988 – 2000 9.16 Need (2)
Fork Bush Slider 51415-KCR-003 1988 – 2000 7.56 Need (2)
Fork Bolt 0-Ring 91356-KF0-003 1988 – 2000 2.86 Need (2)
Fork Slider Bolt 90544-283-000 1988 – 2000 2.01 Need (2)
Washers
Fork Backup Ring 51412-MB4-003 1988 – 2000 7.15 Need (2)
Fuel Filter 16900-MG8-003 1988 – 2000 15.06
Fuel Reserve Sensor 37810-MN5-008 1988 – 2000 unavailable
Fuel Pump: Airtex E8371 (After Market fits GL1500).
Fuel Pump Strainer: Carter STS2 (After Market for the Airtex E8371 Fuel Pump).
Gear Position Sensor 35759-MN5-003 1988 – 1989 unavailable
Gear Position Sensor 35759-MY4-000 1990 – 1997 52.31
Gear Position Sensor 35759-MAM-A81 1998 – 2000 53.91
Gold Wing Emblem 83605-MAM-A81 1999 23.11
1999 Battery Side
Hazard Relay 38301-MG9-681 1988 – 2000 39.94
Left Combination 35020-MAM-A70 (SE) 1997 – 2000 104.31
Switch 35020-MAM-A60 (Aspencade) 1997 – 2000 104.31
35200-MT8-772 (SE) 1990 – 1996 Unavailable
35200-MW5-013 (Aspencade) 1991- 1996 Unavailable
35200-MT2-003 (Gold Wing) 1990 Unavailable
35200-MT2-003 (Gold Wing) 1989 Unavailable
35200-MN5-010 (Gold Wing) 1988 Unavailable
Note: (Turn Signal, Horn, Emergency Flasher, Dimmer Switch)
Oil Seal 91261-ME9-005 (1) 1988 – 2000 7.91
(Drive Shaft)
Oil Seal 91206-286-013 (14x28x7) 1988 – 2000 2.31
(Gearshift Spindle)
Radio Light Bulbs 39111-MCA-671 1988 – 2000 4.16
Twist-In Bulbs Panasonic Number: XAMR011SA
Note: These bulbs fit the GL1500 (1988 – 2000) and the GL1800 (2001 - 2010)
Radio Light Bulbs XAMR001SA (1) (wire harness, connector and two bulbs)
Note: No longer available from Panasonic Services Co. Parts Division.
20421 84th Avenue South
Kent, WA 98032
1-800-833-9626
Rear Wheel 06410-MZ0-A00 (1) 1998 – 2000 32.80
(Damper Set)
Relays # 3 Tail Pilot # PL-RY1 (Auto Zone)
Main Relay Pilot # PL-RY-1 “NV-RY1, on Package” (Pep Boys)
BWD # R4136 (O'Reilley Auto Parts)
HMC DEKO 95220-22100 (Hyundai Car relay)
G8MS H-30 (Auto Zone, Advance Auto)
R4754 (Advance Auto and Car Quest)
Right Combination 35013-MAM-A70 (SE) 1997 – 2000 86.08
Switch 35013-MAM-A60 (Aspencade)1997 – 2000 86.08
35130-MT8-771 (SE) 1990 – 1996 Unavailable
35130-MT2-003 (Aspencade) 1991 – 1996 103.22
35130-MT2-003 (Gold Wing) 1989 - 1990 103.22
35130-MN5-020 (Gold Wing) 1988 Unavailable
Note: (Starter/Reverse, Cruise Control and Engine Stop)
Reverse Lever Switch 35370-MN5-003 1988 – 2000 14.41
Note: Listed under (reverse bar) on Honda fiche.
Reverse switch 35600-MM5-003 1988 – 2000 12.32
Note: Listed under (gear shift fork) on Honda fiche
as “neutral switch”.
Rubber Grommets 83601-MN5-000 (2 - front top) 2.18
For Side Panels 83551-300-000 (2 - front bottom) 2.79
83551-MA6-000 (4 – rear) 2.55
Side Stand 50532-MT8-710 1988 – 1991 unavailable
50532-MY4-700 1992 – 1994 unavailable
50532-MAM-000 1995 – 1997 unavailable
50532-MAM-A80 1998 – 2000 37.10
Side Stand Switch 35710-MN5-003 1988 – 1991 unavailable
35700-MY4-305 1992 – 2000 38.98
Spark Plugs (NGK) DPR7EA9 1988 – 2000 2.19 Need (6)
Speedometer Cable 44830-MN5-000 1988 – 2000 19.86
Assembly
Speedometer Inner 44831-MN5-000 1988 – 2000 7.41
Cable
Speedometer Drive 44806-MT2-003 1989 – 2000 19.96
(Plastic Gear)
Speedometer Drive 44806-ML7-003 1988 18.21
(Plastic Gear)
Speedometer Box 44800-MT2-003 1989 - 2000 68.08
Assembly
Speedometer Box 44800-ML7-003 1988 64.84
Assembly
Starter Brush Set 31201-MT8-008 1990 – 2000 20.40
Starter Relay A 35851-MF5-751 1988 – 2000 65.01 All Models
Starter Relay B 35850-MN5-000 1988 – 1989 Not Available
Starter Relay B 35850-MT8-000 1990 – 2000 65.01
Starter Motor 31200-MN5-008 1988 – 1989 Not Available
Starter Motor 31200-MT8-018 1990 – 2000 477.96
Starter Motor 31200-MW5-871 1991 – 1996 635.75 (Interstate)
Sub Air Filter 17253-KT8-000 1988 – 2000 2.52
Turn Signal Relay 38301-MG9-681 1988 – 2000 39.94
Timing Belts and other parts:
Timing Belts (Honda) 14401-MN5-004 1988 – 2000 57.91 Need (2)
Timing Belts (NAPA) 250275
Timing Belts (Gates) T275
Idler Adjusters 14510-MG9-008 1988 – 2000 77.89 Need (2)
Tension Springs 14516-MN5-000 1988 – 2000 2.91 Need (2)
Tires:
Tire Valve 42753-MN5-004 1988 – 2000 10.08 Need (2)
Tire Valve Holder 42754-MN5-000 1988 – 2000 3.91 Need (2)
Tire (Front) 130/70HB18 (Bias Ply) 1988 – 2000
Tire (Rear) 160/80HB16 (Bias Ply) 1988 - 2000
Fluids and Grease:
Honda Pro Brake Fluid (Dot 4)
Honda Moly 60 Lube (3 oz tube)
Final Drive Oil (85/90 weight gear oil)
Antifreeze Coolant (50/50 Silicate Free)
Helluva job DBohrer!!!
My ONLY comment is that the NAPA/Carter P72190 fuel pump (aftermarket) is rated closer to the OEM spec.s than the Airtex fuel pump. The Carter strainer fits nicely with it too. The NAPA/Carter pump is/was priced a bit lower and there was a "not in stock" problem with the Airtex when I was in the market for a fuel pump replacement.
Nothing wrong with listing BOTH pumps and give the guys a choice. IIRC both work fine.
We have used both pumps with no issues. I am aware of the pressure ratings.....!!!!
Thanks for the list. Finding what group Honda put something can be a real pain sometimes. (most of the time)
Bank angle sensor under engine guards? Really, Honda?
I agree..............!!
Try finding the "Control Unit High Mount Accessory Light" for the trunk light on the SE models.....!!!!
It alternates voltage between 12 and 6, depending on input from the running lights or brake lights.
