anyone got a quick fix for this? everything works but the push to talk button takes several seconds before it pops back out. thanks. Mark in MN
WD40 might work, but more often than not it won't get past the seal behind the button. It's still worth a try, if it doesn't work you will have to strip the switch and clean it, then put some new dielectric grease inside.
I had this happen before and had to strip it down, the spring was full of muck so I cleaned it all out and just put copper grease in and it worked fine until I sold the bike.
Other side of the pond
J&M do (or used to anyway) a much better one. It has the CB button and a proper radio volume control and channel switch for about the same money as the crappy Honda one. But the lads are right, if the WD doesn't work, a good cleanout usually does.
