Probably a cracked solder joint in the radio.
+1 the connectors sometimes are loose and slip off or a pinched wire.after the connector,first place i'd check would be the speakers
Both front and rear, only the right side. If I reach under the top cover and jiggle the big rubber boot around the connectors, the right side comes back on -- speakers and rest of the wiring has to be good, problem is at the connector.
Thanks, DaveYou guys are just not paying attention.
Thanks, Dave
Its not in the fader, I can physically move the one connector at the radio and make it stop or start. Just looking to know if there is a known problem either with the wires, connector, or the pins coming out of the radio.
