Own sidecar rig. Always try tocheckbrake pads, as theyworkharder.Run EBC HH pads on Wing;haddone both front in early Spring. Waited a few weeks on rear,to putnew rear tire on, replace rubber drive blocks, relube splines anddo alltogether. Had previously checked rear caliper andthe brake pad I could see showedlittle wear. Assumed all was well ........WRONG!
Rearcaliper floats on twin pins, so it can move left/right and padswill wear evenly. Upper front pin was fine[well lubed]. Lower rear pin was FROZEN in caliper, due to lack of lubrication and resulting severe corrosion[rubber boots on pin were very brittle; crumbled when working on pin removal]. This forced severe wear on one pad and when caliper was pulled, back of worn pad was only a few miles from metal-to-metal contact withrotor!After pin was freed up[a NASTY job!]so much play resulted due to wear and rust removal, that new OEM pin from VENCO literally floated in it'scaliper bore!Must now obtain new rear caliper; replace during winter rig storage. A BUMMER, but am Most Grateful this problem was found in time!.
It appears to yours truly that design of rear pin setup, could have been done better, w/ MORE lube storage built in[has very little]. If this had been done, I doubtit would have been necessary for me to replace the caliper at all. Hope this helps others. TTFN......Old Tom aka papasmurf in NH
