GL1500 Rear Brake Mystery, help!
503 Views 5 Replies 5 Participants Last post by  Waldorf
I have a 99 SE thats got me puzzled. over the last 3000 miles they rear brake has lost the the brake fluid. no sign of leaks anywhere.refill it and bleed it and its good to go for awhile. I am stumped. Any theories, suggestions, new cuss words?
Being a sealed system, There has to be a leak somewhere. Possibly a small crack in the bottom of the reservoir, or at the left front brake which is tied to the rear break.
new cuss words?
"Linfrantzenmeck", and "Stridelnagenhof".
+1 on front brake, if it's a linked system.
There can be a crack in a steel line not necessairely close to the wheel trace the line and clean with brake kleaner, the apply brakes to presurise sytem, look for small leak sometime it could take a bit of time but if the line has dirt and black gracy stuff its a good sign of oil accumulation absorbed by the dirt. its a sealed system oil has left the bike somway or an other.
Does the 99 SE have a linked system? I thought all the brake lines were rubber lines.
Just asking cause I havent had this bike but 6 months.
The bike HAS linked brakes. The handlebar brake lever operates ONLY the front RIGHT disk brake. The foot brake pedal operates the front LEFT disk brake & the rear disk brake. There are a mixture of rigid steel brake pipes & rubber flexible pipes in the braking system, you will find that out when you do the routine maintenance after taking the tupperware off.
