hello everyone...
yes I back again to work on this dame cruise control I have on my gl1500 1988 model.
I have done the clutch and the cruise control value checks...ok on both
power to the unit is also ok...
now the next part refers to as noted below
Throttle, Front and rear brake switches
The next bit needs a little explanation so you are aware of whats going on. The throttle, Front and rear brake switches are wired in series this means we can test all of them at once, these switches are the safety circuit which holds in relay 2 (the cruise set relay) which applies the live feed to the vacuum solenoids.
I have looked on my manual and have not being able to find any notes on where RELAY 2 is. can anyone help.
also the position relay, is a 10a-12v unit, i did the same test, asper the crusies control relayand have notice that when connected to 12v and then tested, there was noresistant noted on my meter
so what does this relay do...
i was wondering that the postion relay has something to do with the 4/5 gear switch
and its not working, that could explain why my cruise control is also not working.
any help would be appreciated
thanks
bye
hello everyone...
thanks
bye
