1 - 18 of 18 Posts
Hi All,
Got out for the first time this year and I stopped for gas before going home and noticed after I got it that my gas gauge and heat gauge wee not working. And on the way home the OD light was also not working. After I got home I noticed the the lower cowling light wer not working also. I'm thinking it maybe a relay but did not have time to loo at it (had to go to dinner with some friends). Ijust wondering wer to start looking. I hate electical problems.
Hickey
i would start with the fuses
Dave0430,
Were may that #3 relay be ? With all the other relays behind the left saddle bag?
Hickey
Discussion Starter · #11 ·
Well the nexted couple of days are not looking good to work on it (small shed 8 x 8). I have to work on it outside. Will let everyone know what I find out. Anyother suggestion will be looked at also.
Hickey
Well, I put a new fuse in my 1500, and it blew soon after I drove it today. The last time it happened I remember it was the front fog lights that were causing the problem. My fault though. I had been saving old bulbls by bridging the gap between the 2 connectors on the bulb with solder. For the second time now the solder started to melt, and run against ground on the holder. I`m just buying new bulbs from now on when one burns out.
Can a bad relay burn out a fuse?
gumbyred
Discussion Starter · #14 ·
I know under the old website there was a list of Auto Parts replacement parts. There was one for relays but I can't remember what it was.
Does someone remember what it was?
Hickey
I just had the same problem too with my 99 se. It was the 15 amp fuse that blew for some reason. One minute it was working the next minute the fuse was bad. Go figure.....
mr irrelevant
The relays are located behind the left saddle bag and side cover...i would switch it out with your air compressor one to test and see if that is the issue. Relay #3 is the likely culprit....relay # at autozone is for a pilot relay PL-RY1...should be about 9 bucks or so and you may have to order it in....
Discussion Starter · #17 ·
Well, got around to seeing what the problem was. I checked all the fuse with my test light and all were working. So I moved to the relays and the same thing All working. I sat back and did a little thinking and all I could think was a fuse. So I desided to pull all the fuses out and replace them.
I started with the one that said instrument and truck lights (it checked out OK with a test light) Pulled it out and one blade stayed in. Replace it and Alls well now. I guess by pushing the test light point on the fuse it made contacted. It was not blown but broken were the small wire connects to the blade.
Thanks All for the help.
Hickey
2000 GL1500SE
Good info. Thanks for the update.
1 - 18 of 18 Posts
