Can anyone help with a reverse problem on a GL15? A) there is no reverse, B) no charging and C) if engine is running, turn off key...engine still runs. Remove all relays and fuses....engine still runs. I thought that relays 3 and 8 removed ALL power via the kill switch and the common of the coils. I think the reverse diode block is faulty, but any help would be appreciated
You should really get the alternator checked first, if it isn't charging teh batter this can make other electrical items go a bit wonky on the gl1500.
What year GL1500 ?
You are checking for charging how ?
You pulled the main fuse and the bike still runs ?
I have some of the earlier wiring diagrams and may be able to send you a couple copies, PM me with e-mail info.
I'm kind of tied up until early next week, so it may be a day oy two.
2019 DCT Tour Ardent Red
Cat,
What year and model?
Do you have a decent wiring diagram?
How do you stop the engine?
Was anything repaired, tested, installed just before this problem started?
Certainly sounds a bit weird...somthing is powering the ignition beyond the kill switch?
I'll try to help...best I can
Greg
Other side of the pond
welcome to teh forum cat. I think we need a bit more info before I get stuck in. Like if the charge isn't geting to the battery, is ther a good charge coming out of the alternator itself?
