1988 Goldwing GL1500. With air box off I can see inside top of carbs and the right carb has fuel pumping out the top orifices for a few seconds when I hit the key. If it starts....... the orifices start vomiting up gas much faster than carb can use. Left side acting just fine! I have read to lightly tap on float bowl to unstick float or float needle. It sometimes works but the next time you try to start the bike it happens all over again. I can't carry all the tools in my saddle bags to remove all plastic when this happens miles away from home.
I am at wits end. Spent 3 days trying different fixes that I read could be problem. What ideas do you have? What else could I try? I think I have replaced everything.
Changed out:
Changed out:
- Gas in Tank with fresh gas
- Fuel Pitcock
- Fuel Filter
- Gas Line
- Vacuum Lines
- Carb Jets
- Float
- Float valve needle
- Needle Seat
- Filter on end of needle seat
- Rubber boots carbs sit in
