Hi everyone. I'm new to Goldwing Facts so pleasebear with me. I have a '88 1500 I bought for $500 it has 74000 miles. The fuel filter was plugged when I bought it3 years ago. I replaced the fuel filter, air filter and plugs. The bike purred like a kitten until this year. The battery diedlast springso I changed it and when I took the bike outit was running really flat from idle to 2200 rpm then it felt like a two stroke power band kicked in and it took off. I ran 1 bottle of Sea Foam in 2 tankfulls of fuel and it did not help. I parked it untill this weekend because it was kinda scary to ride (I've been riding Wings for 20+ years) anyway it took a long time to fire but when it did it idled and ran great in nuetral. I took it out today and it ran great untill it warmed up then the problem started again. I was hoping someone had an idea of what to check.
Possible the fuel filter is plugged up again. Is there any rust in the gas tank? Seafoam could have loosened crud.
Gumbyred
Gumbyred
> If it was a plugged fuel filter, then the bike would not be able to run normally at the higher rpms... eg It would have a constant loss of power at all rpm's
Oddly enough the first thing I would suspect is vacuum leak then clogged carb's
I still think you would be surprised if you just took the fuel filter off and see what drained out of it. Cost you nothing.
A few weeks ago I asked a question about my `98 S.E. acting like it was starved for gas going uphill. Cut out bad at 65. Took it up the same hill recrntly at 75, with no cutout. Only difference I can think of was gas tank was 1/4 full before when it would cut out. Had a full tank of gas when it wouldn`t. Maybe fuel pump is
getting weak? I`m still monitoring.
I can`t figure out how it would run better at high R.P.M. than low R.P.M. with a vacuum leak either.
Gumbyred
If the slides inside the carb were stickingcould it cause this problem. I'm wondering why it seems to be worse when it's warm
Discussion Starter · #8 ·
I'll change the fuel filter and test (weather permitting ) while I try to get to the vaccuum lines. I bought a set of 1990carbs off of ebay. Think I should rebuild them and put them on while I'm in that far.
