The tachometer stopped working on my 99 SE and after taking to my mechanic they checked the engine control module and all the wiring and determined that the tach was bad and the only way to fix is to replace the whole instrument cluster(very expensive) the bike only has 12,000 miles. Can you just change out the tachometer assembly or does he entire cluster have to be replace, any advice or suggestions would be appreciated.
Discussion Starter · #2 ·
Yea definitely going to a differnet dealer for a 2nd opinion I saw the tach assmembly on the OEM schematic so having to replace the whole cluster did not make a lot of sense, thanks for the input
