1 - 11 of 11 Posts
I installed the 12 volt multi fuel shut off valve on my 88, wired to the acc terminal, the valve gets hot, after riding for about 10 miles, stopped and the valve was very hot. help!
Official "Cheeky Plonker"
OoooH, questions? questions? First one being, why do you need it?
Monkey with a Football
Have you contacted the people where you got it to ask them how warm it should run?
It's possible you got one with a shorted winding or something like that.
Dan-Marc
812 S. Tuscarawas Ave.
Dover, Ohio 44622
330.343.5307
A simple Google search found the above information. I've used the above valve for well over 10,000 miles w/o any problems. I've never touched the valve when riding to see how hot it got. Tomorrow I'm commuting 65 miles to & from work. I will leave the fuel door open, reach down & feel my valve. I just hope I don't get busted for doing something indecent.. :ROFL:...-Rich
Anti-Guru
The valve dissipates ~9-Watts (0.75A at 12V, ); this is roughly 3-times the power from a #194 marker lamp (0.27A)
Try holding a lighted #194 bulb in your fingers for comparison... :ROFL:
There's really not much of a comparison actually, your fuel solenoid is substantially larger, so there is more surface area to dissipate the heat. But, yes, it is disipating slightly better than 9W and that 9W will be warm to the touch. The tiny amount of fuel (0.156" flow diameter) will not be absorbing much heat from the device, so the rest of the heat must dissapate out to the case. Add that to being in a warm area of the bike, and yove got a warmer valve.
If you're worried about it, more airflow may ease your mind, but, unless you can boil spit on the surface of the solenoid, I'd suspect that the valve is operating well within design parameters.
Dan-Marc
Dover, Ohio 44622
330.343.5307
I did feel the valve going down the freeway, & although it does get slightly warm after several miles, it did not get hot as the OP posted....
-Rich
1 - 11 of 11 Posts
