You don't give us any clue where to start from, just that it died and won't start and that could be 50-100 things maybe.
Start with checking to see if the fuel pump is pumping or not. Could have blown some fuse or pump went bad. Could be the fuel petcock near the gas cap went bad and not letting gas flow to carbs or a busted vacuum line and it's not working.
Might even been some bad gas with water etc...
If it is getting fuel, then is there spark to the plugs? If no spark it could be a simple fuse blown or something else.
Did you bump the kill switch and not notice it got turned off? LOL
Sometimes a kill switch can also go bad, may crank well but no ignition for it to start.
What lights are on on the dash when you turn on the key and let it sit. Sometimes that may lend a clue.
88 can be different than some of the newer 1500's also.
My 88 I can hear the fuel pump run just turning on the key, sometime it got changed and the pump only runs when hitting the starter button on newer ones like my 95.
My 88 the reverse will work with key on engine off, but my 95 it only works with engine running.
So though all 1500's are basically the same in most ways the 88 and 89 do have some differences from newer models.
I don't remember off hand for the 88 what lights should be on on the dash with the key on and kill switch on, but if kill switch off or bad I think there is a light that does not light. Might be the cruise lights? Turn on the key, press for cruise control to be on, then flip the kill switch on and off and see if any lights go out or on and let us know.
I think I would start with checking for fuel first, after checking the switch. Remove the fuel line from the petcock and run it into a container and see if fuel is pumped from the tank.
