I have a 92 1500 SE trike. I can not get the radio fader to work. I put a new fader on it worked for a little while but only the front speaker worked. Can I unhook the fader wires and hook just the front speakers to work? And how do I do that? Thank for the help.
sounds like you have a connection problem
Yes you can have just the front speakers. Connector is behind the left shelter panel.
Have you checked the wires for the rear speakers? Many times others route the wires wrongly and they Ger pinched and broken by the trunk hinges and that is a common reason the rear speakers don't work.
huntermangofast wrote:
Do I just discont the fader wire from the behind the panel. And plug the wire back into them self.
If it's plug and play, yes.
