1 - 9 of 9 Posts
The speedometer, odometer & cruise control all stopped working. I'm wondering if this could be the speedometer cable in need of replacement. I find it interesting that the cruise control is not working & I believe it's because of speedometer. Can anyone help me please with advice or tips??
Uh...yep...that could be your culprit. At the front wheel, disconnect the speedo cable and try to remove the actual "drive cable" if it stiff, it could be dry or rusted, if it comes out in pieces...well, it's broke. if the cable is good...then it's the drive gear in the front wheel speed housing that needs replacement.
Dennis, yes, you're right about the signals that doesn't work with self cancelling too. I guess I will set up an appt at garage to fix it. Thanks all!!!
...I guess I will set up an appt at garage to fix it. Thanks all!!!
Its pretty easy to replace the speedometer cable/housing... only takes about 10 minutes, and $20
Hi all, just had it diagnosed & it's not the speedo cable. It's the sensor housing at the bottom of the cable so that's being ordered now. Should arrive here some time next week...
I'm having the same issue - how did you diagnose it?
Wild Rhino - Canadian
Get the front wheel off the ground and spin the wheel, if the speedo drive turns it should be good, then you would be looking at the cancel control
1 - 9 of 9 Posts
