GL1500 Starter Motor Repair
8737 Views 12 Replies 9 Participants Last post by  Lou Sharpe
I've finished the GL1500 starter motor tutorial, hopefully it will beof someuse. Anyone who needs it can see it here;
http://www.goldwingfacts.com/1500startermotor.htm
I made a video of it as well and I'll get that edited and uploaded late in the week.
1 - 13 of 13 Posts
:clapper: Very Good !
G
Thanks wingnut.
Fantastic, even for a person not even technical minded.
Thank You. :clapper:
Exactly what I needed, Thanks!!!
Thank you, thank you, thank you...
...this was perfect timing. My starter motor has been sluggish for a long time & won't pull well in reverse. The dealer wanted $165 just to remove it and aroun d $500 for a new motor! I got the feeling he just wasn't interested.
My dad is a retired auto wrench and he said he would do the job if I found a manual or how-to, otherwise he would be feared of breaking things looking for the motor. I been here lurking in the past and when I looked yesterday, lo and behold what do I see staring me in the face but an animation of starter removal and repair. My dad don't use computers (heck he don't even like television) so I printed it all off on 10 pages and dad read it, grunted a few times and tore into the Wing. The starter was on the floor in about an hour.
We had a beer and dad put the white sheet on his workmate and stripped the motor. FULL OF BLACK POWDER/DUST and one brush has crumbled to nothing, but it looks good and it seems like we will get away with new brushes and a good cleaning. Dad cracked open the part with the gears and cleane and greased it all before putting it back together. He will clean the copper parts today and one of his buddies will match up the brushes with some from a car and solder them in for us for a few beers in exchange.
I wanted to share this with you because I think what you guys do here is a good service. For the price of a few beers instead of nearly $700, my Goldwing will be back to normal.
You guys are the greatest.
Some mechanic told me that he always cleans/increases grooves between copper plates on rotor. He made tool from saw blade.
In some...
In some...
yes the tutorial mentions cleaning the gaps between the copper bits, I suppose it's common sense really.
[align=center]I've copied the article into this post for quick reference.
Click the thumbnails for a bigger image, they will open in a new window.
Disconnect the wire at the starter terminal. 1988-89 models have two terminals, all other model years have one.
When pulling the starter motor out, it will probably be a bit stiff and will need to be wiggled from side to side.
A rare view of where the starter motor engages.
Here are the old starter motor brushes and plate, note the layout and text tips in the picture for reassembly time. The plate pulls away easily.
Now for the gears...
When reassembling the gears make sure to put some grease in there and remember to put the large o-ring back between the two gear case halves.
The cleaned up armature and new brushes back in place. Remember to grease the bearings at each end of the armature before putting the end cap and gear case back in place, and don't forget to put the large o-ring on each end as well.
The starter motor mounting bolts. The longest one goes to the bottom Cleaning them with a wire brush makes them easier to refit.
[/align]
[align=center][/align]
I've uploaded part of the video tutorial. Part 1 shows removal of the starter;
http://www.goldwingfacts.com/Videos/gl1500startermotor1.wmv
I've tried to increase the video quality so you can see more detail. This means the file sizes are larger than usual, so I've made the video in three parts. This part is about 18.5mbs file size and three and a half minutes long.
This is great stuff. My 1989 starter needs to be done. I tried the direct cable from battery o the + starter posts (mine has 2 posts and I believe the 1988-89 models are like that) and it still turned slowly. I have a spare starter ready and I used the information here to open it up and clean the dirt out.
Part 2 of the video tutorial is available and it shows the starter being stripped down and serviced;
http://www.goldwingfacts.com/Videos/gl1500startermotor2.wmv
9 minutes long and I'm afraid 49mbs, but the quality is fairly good. Part 3 will show the reduction gears being serviced.
This is very helpful, thank you. My aspencade is sluggish to start and I can't say if the battery or starter is to blame. My son-in-law is going to check it at the weekend and these articles will make the work easier.
1 - 13 of 13 Posts
