Ok, not sure if you are aware of this, the 1500 has a safety switch on the kickstand, if it is down, the bike will NOT start unless in nuetral...no matter what else you do it will not start in gear if kickstand is down....takes a while to get used too...climb on to ride her, put kickstand up while in gear, pull in the clutch then start it....try that...
