1 - 2 of 2 Posts
Just started a multi-day ride, two up, luggage, on a 1994 GL1500. The front forks have had the progressive mod made. However, the front seems fairly stiff. Not a lot of compliance there for small bumps. Is that normal, fairly heavily loaded? Or is there something I should check?
Thanks, Mark.
Two things come to mind...........
1. Do you have any air in the forks?
2. What weight fork oil did you use with the Progressive
springs? I am running 10 weight fork oil and will
probably go wth 8 weight the next change.
Those Progressive springs are considerably stiffer than the stock springs. No need to add any air to them.
1 - 2 of 2 Posts
