I just saw a previous post decribing what I am having. Also saw a long list of things to check and will do that tomorrow.
Definately check that Kill Switch on the Handle Bar... they commonly fail due to either corrosion on the contacts or (harder to find) due to loose screws on the wire terminals to the switch themselves. Could also be the Kill Switch on the kick stand... You can easily bypass it (temporarily or permanently), and/or the one on the handle bars.The GL1500 that I just replaced a leaky fuel line and a leaky Petcock has a new problem.
Took off from house bike was running fine. Still have to choke it till warms up to get it running right.
After I left the house ran into rain storm. Bike seemed fine. After about 20 minutes while going 60mph the engine died. I had electrical power it was like I hit the kill switch.
Coasted to the shoulder of the road. I opened the fuel cap to make sure I hadn't ran out since it showed 1/2 a tank. I did notice no fuel in the new glass fuel filter I installed.
Not sure if electric fuel pump died, got water in the wires or something? Just got the bike a few weeks agao and first ride in the rain.
Not sure where to look first. Sat for 6 hours in the pouring cold rain trying to get a wrecker that takes bikes to come pick me up....
> "Just shut off like I had flipped the kill switch."Check you BAS too.
Did it sputter or off like switch?
You replaced the Fuel Petcock right?... If so, then might try By-passing it, in case it's not opening and/or manually fill the fuel line from the petcock to the carb, and see if the engine starts upon receiving known gas....When I turn on key, then switch the kill switch to run I hear a hum like the electric fuel pump. I rocked the switch off and on and the fuel pump hummed up each time.
Tried to start and nothing but the starter spinning. I still see no gas in the fuel filter even though I hear the hum...
