Okay, I have a stumper for you all. I have a '96 Goldwing 1500 (25k miles) that is experiencing what appears to be a fuel delivery problem. Over the past 4 years it has quit several times for no reason, seemingly more often lately.
Here's the deal: I live in the foothills of Colorado and ride up in the mountains as often as I can. The bike runs great for miles and miles, then will hesitate a little, maybe stumble, then run great if I crank the throttle. After another minute or so, the bike just dies out completely. Choking it seems to help for a bit, but eventually it will just quit. Even going downhill (push-starting) at 35-40mph it will not start.
After sitting 3-5 minutes the bike will start with full choke (dies without it), and soon enough is running great again. It can run 50, 100, 500, or 1,000+ miles without stumbling again. Today it quit twice in 5 miles, then ran pretty well for the 50 miles home.
Here are the typical conditions each time it happens:
+hot weather
+higher elevations (10,000 feet, but not always)
+half a tank of fuel (filled at lower elevation)
+slower riding (35-45mph)
+usually quits when going downhill (but not always)
I've replaced the fuel filter (EMCO, just read the threads about that, so will get rid of that ASAP). Also did air filter, cruise and sub filters while I was in there.
Would the vacuum petcock cause such problems? NO signs of leakage or corrosion, all looks good. My assumption is that if the engine is running, the valve is opening. If it fails, does it fail open or closed?
If the fuel pump is failing, will it get sporadic, or simply fail and be done? That's always been my understanding with fuel pumps -- either they work or they don't.
Any ideas? I don't dare take it anywhere until I get this figured out. Sooner or later it WON'T start up again.
I appreciate any advice anyone might have. Thanks.
dwlarson
+hot weather
dwlarson
